OctaneRender™ for Blender 1.20.2 - 2.8 beta Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed emission node bug.
  • Minor fixes...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v2.8 beta Linux (128MB autoinstaller file)
belloq
When installing blender octane in the terminal I get this error:
Error: Could not load binary data file '/usr/lib/octane.dat'ERROR: Program executed illegal instruction.. terminating
When trying to render in blender I get this message in the console(I have a GTX 460 card):
ERROR: CUDA device 0: Failed to find a CUDA binary matching compute model 2.1
I am also not sure how to start the render server in linux :?
Thanks for your help!
mib2berlin
Hi, I install Octane Bender manually with:
octane_blender_1 -e
-e extract the package to a new folder "Blender Octane"
Copy all in "lib" to /usr/lib64 or /usr/lib, depends on your distribution.
The other folder include Blender and the Octane Server.
Start Server from a terminal with ./Octaneserver
./Octaneserver & will start server as daemon.
Start Blender Octane the same way.
If you close the terminal the application is closed too.
This way you have control where all files are.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
belloq
Thanks for your help mib!
When using -e I get this message:
paul@paul:~$ '/home/paul/Downloads/octane_blender_1.20.2-2.8.run' -e
head: cannot open ‘../..//home/paul/Downloads/octane_blender_1.20.2-2.8.run’ for reading: No such file or directory
gzip: stdin: unexpected end of file
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
mv: cannot stat ‘./usr/README.txt’: No such file or directory
I am using ubuntu 13.04 / 64 bit i7 / nvidia GTX 460
mib2berlin
Hi belloq, i am very sorry, forgot to put sh in front of command. :oops:
sh /home/paul/Downloads/octane_blender_1.20.2-2.8.run -e
Cheers, mib.
belloq
Thanks for the update ;) but I still get the same message.
Maybe I am missing some libraries?
mib2berlin
Hm, looks like a path problem.
I am in the root folder, where the .run is.
May this is the problem.
JimStar fixed all the library problems we had in earlier versions and you get other error messages.
Cheers, mib.
belloq
Tried with
./octane_blender_1.20.2-2.8.run -i
now everything is working :D
grimm
Just another update on the OctaneServer crashes, if it helps. It looks like the server acts differently when it's in use vs. just waiting. I was in the middle of using it when it crashed with this error message:
jason@gemong bin$ ./OctaneServer
Segmentation fault
At that time Blender had these error messages:
Octane: Network send error
Octane: ERROR resetting render server:
The Blender errors are probably just because it could no longer talk with the server, but I thought I would add them in to be sure.
Jason
grimm
Looks like the settings for the Octane camera don't get applied to the final render (F12). In particular the setting for the hot-pixel removal which I can get working in the viewport render but not in the final render.
Return to “Blender”
