OctaneRender™ for Blender 1.20.2 - 2.8 beta Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed emission node bug.
  • Minor fixes...
Blender Octane Edition - 1.20.2 - 2.8 beta (2.68a) (51.8MB autoinstaller file)
Octane Server - 1.20.2 - 2.8 beta (32.4MB autoinstaller file)
aLeXXtoR
Thanks!!
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
rattle-snake
Merci beaucoup !!!!
suvakas
Just wondering.. is there a reason why you keep compiling 2.68a and not the final 2.69 ?
Is it a lot of work to migrate?
Suv
MattRM
Thanks !!! You're Rocks
Matt
suvakas wrote:Just wondering.. is there a reason why you keep compiling 2.68a and not the final 2.69 ?
Suv
It's just a few minutes to merge and resolve conflicts of the code text itself, but it takes a lot of worktime to check that the patched part has no logical intersections with all the newly rewritten Blender internals.
So, this task - is a separate thing, which may add some new bugs, so it should be released after all the current bugs are fixed and we've got the stable release, and it should be tested on its own.
Inciner
Sweet!
Refactoring is always mentionable part of any coding work!
Let's try this one)
Яussian engineer (AutoCAD+LISP/Blender 2.69/3dsmax/Mypaint/GIMP) | win7x64 + GT525m DELL || win8x64 16Gb RAM 2x GTX 770
Inciner
Sorry, no response at win 7x64 Gt525m Dell Inspiron
suvakas
JimStar wrote: It's just a few minutes to merge and resolve conflicts of the code text itself, but it takes a lot of worktime to check that the patched part has no logical intersections with all the newly rewritten Blender internals.
Thanks. I thought it's smth like this. I was just curious ;)
Awesome work with the plugin btw. 8-)
Suv
Marten74
Thanks Jim for your replies in the previous release.
So, UV unwrapping works as long as you create the Octane material node network with a texture first. I´m happy with that =) Is it a mess to make the UV-unwrapping work before creating the octane nodes to? Just thinking of new users that might run in to this "issue".
I still can´t open IES files (.ies). Is it supposed to work in the plugin? In the stand alone I can open my .ies files with the floatimage node (textures/images/floatimage). I opened Mib2berlins test scene (thanks for sharing the file). I can see that there is a .IES file loaded in to a floatimage node that focus the light beam. I can´t control the angle of the beam though. When I try to open my own .ies-files through Mibs node, I see no files... I renamed one from *.IES to *.ies with no success (long shot). What can be wrong since I have it working in the external renderer?
The shadow artifact with the light emitting cube was because I missed that the direct lighting was in a different mode for the plugin and the external renderer (as you thought). When I compared again with diffuse mode in both I notice a little speed difference and I could not find any difference in the Octane kernel settings. Probably had some other setting differ, because it should be identical, right? Materials and lights were the same though. I think it was something like 11.8 Ms/sec inside Blender and around 14 MS/sec in the external.
Thanks again
Return to “Blender”
