OctaneRender™ for Blender 1.20.2 - 2.6 beta Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Added "Subframe Motion Blur" feature. So far the "Movable proxy" objects feature is not fully implemented, so this motion blur will work not with the full possible speed. After "Movable proxy" feature will be implemented in next versions - this motion blur feature will become a lot faster...
  • Added "Interpolated vertex normals" info-channel type.
  • Minor improvements and bug fixes...
Blender Octane Edition - 1.20.2 - 2.6 beta (2.68a) (51.7MB autoinstaller file)
Octane Server - 1.20.2 - 2.6 beta (32.3MB autoinstaller file)
bluerocket
Thanks JS
Regards
Asus Rampage IV Extreme | i7-3930K | 32GB | 2x GTX TITAN | 2x GTX670 4Gb | Win 64x
rootaman
Thanks... the ScaleY still not working for the image texture node... I hope this will be fix in next release ;)
rootaman wrote:Thanks... the ScaleY still not working for the image texture node... I hope this will be fix in next release ;)
Yep.;)
I was just concentrated especially on Motion Blur for this release, it's a big chunk of work... So, will close other little tickets in next release...
suvakas
Is the motion blur Octane feature now or is it still a "hack" ?
Suv
lakris
Where will i find the LiveDB in Blender, if it's available?
EDIT: ok, i've found it, but how do i apply it ti fex. a cube?
EDIT2: ok, i got it ;)
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
Force44
Tnx!
But i see some lags in this version
1.When i resize any windows i have a really long time pause and blender hanging
2.When change material and window render active i have the same bug.
http://www.picfad.com
Core i7 2600k @4.2 Ghz | Asus Maxiumus V Extream | 3 x GTX 590 watercooled| Crucial Ballistic Sport 32gb | Crucial m4 64gb | Seasonic Gold 1250 | Octane render| Skethcup Pro 2013 | Blender 2.68
Next version HERE.;)
Return to “Blender”
