DAZ Hair Problem
Moderator: BK
richertmx
Hey all,
Is there any way to make DAZ Hair (Like Duke Hair, Dream Hair etc.) look good when using the octane plugin? Everytime I apply some kind of Hair from within DAZ and Render it, it has no transparency at all and just looks like some hard piece of wood on the head.
Is there any way to solve this? Thanks and best
Gigabyte GA-X99-UD4 | Intel Core I7 5820K | Crucial DDR4 16 GB | 2x MSI Gefore GTX 780ti 1x Geforce GTX 780 | Seasonic Platinum Series 1000W
SimonJM
Check that the transparency and bump maps have been applied correctly (or at all!) in the Octane materials and that they are defined as image, not floatimage.
t_3
SimonJM wrote:Check that the transparency and bump maps have been applied correctly (or at all!) in the Octane materials and that they are defined as image, not floatimage.
hm, hm, i think i have read that once or twice, but why not as floatimage?
sry for asking such a dumb question, but i hardly have the time to try render sthg; afaik floatimage is the ideal type for opacity maps; maybe only exception from my pov if the opacity map is i.e. a .png and has the opacity not as grayscale but as alpha channel (this of course won't work with floatimage).
@richertmx
and on a general note: if the auto chosen map type more often doesn't fit, as otherwise, you should select the map type in the preferences tab, down there in the texture settings from "auto" to i.e. "image"...
SimonJM
@richertmx
Very good question ... I have not done a lot of in-depth checking (in fact, none!) on how maps work for transparency, but have assumed that floatimage produced a differently scaled result to 'plain' image - regardless of file type (greyscale or colour). I almost certainly should try and understand the manual (which I have looked at, it's just that I really do not understand a lot of the technical stuff with graphics ... go much beyond green crayons and I get lost! ;))
t_3
SimonJM wrote:Very good question ... I have not done a lot of in-depth checking (in fact, none!) on how maps work for transparency, but have assumed that floatimage produced a differently scaled result to 'plain' image - regardless of file type (greyscale or colour). I almost certainly should try and understand the manual (which I have looked at, it's just that I really do not understand a lot of the technical stuff with graphics ... go much beyond green crayons and I get lost! ;))
well, IF the opacity map is indeed a color bitmap, this might happen. imo usually they aren't but that is a good point.
btw, the update will read the bitmap data directly to check if the image is actually grayscale before adjusting the auto selection; but there won't be a magic formula, that enables the plugin to apply all and every map as ideal type, etc ;)
Return to “DAZ Studio”
