IPR response
BorisGoreta
IPR doesn't respond sometimes to changes in Octane nodes. Let's take the intensity of the sky node. If I enter a value and hit enter sometimes IPR doesn't reflect the change, it doesn't even redraw the image. I have to slide the value left and right to wake it up. It is so with many input values. Not all the time, but sometimes.
juanjgon
In all Octane nodes or only in the render target ones?
What version of the plugin and the LW (build number) are you using?
BorisGoreta
Environment node intensity was just at 0. Then I typed 1, pressed enter and nothing happened. Then I had to scrub it left and right for IPR to start reacting.
Return to “Lightwave 3D”
