Rendering Endomorphs
fibernaut
Hi
i have some Endomorphs in my scene but octane is not taking them into account. They are set up with morph mixer in the objects properties panel.
Any idea how this is going to work? Or is it not working at all?
Thanks in advance.
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
juanjgon
Any kind of deformations should work with Octane. Can you please send to me a simple scene with your setup to test it here?
fibernaut
Don't know why it didn't work yesterday. Today it works fine. :|
Thanks anyway!
fibernaut
Hi again.
Today i'm on a new scene and it won't work. :cry:
I attached a very simple scene.
The orange bottle in the scene has a morph applied and should "blow" up. The morph is animated via envelope. The same procedure that worked yesterday. But octane does not want to render it. Im in the middle of production and appreciate any help! :cry:
JuanScene.zip
(1.46 MiB) Downloaded 286 times
fibernaut
'Object dissolve' is also not working although it should. :?
juanjgon
The problem with endomorphs is that your scene has enabled the "Instance LW Clones" parameter in the render target options. The instances can't morph becase all of them are a copy of the master object (the first one in the list). If you disable this option all works fine.
Perhaps your problem with dissolve is the same ... dissolve is shared among instances, so with "Instance LW Clones" enabled you can't use dissolve with cloned objects.
fibernaut
This setting solved the issues. Now it works fine, both endomorphs and dissolve.
Thanks you so much for your help!
Return to “Lightwave 3D”
