1500W power supply surging
whersmy
A bit of background information for my question:
My 1500W Silverstone got shut down by my maximus V extreme mainboard due to power surging, because I did not add the extra power plug when using 2x gtx 580 and 1x 590.
When rendering the gpu`s power% sometimes dropped to about 20%, which caused crazy spikes because the power supply delivered the power through the ATX cable, which was too much for the 2 pins.
So when using 2 or more power hungry gpu`s, always add that extra power if your motherboard supports it. Or check with msi afterburner if power spiked happen, and check if your motherboard cable is not getting too hot when rendering :!:
Here`s the plug:
Here`s an example of what the cable looked like burned:
The cables are modular, so I just replaced the atx 24 pins cable, and carefully removed the burned plastic from the mainboard, rendering 100% again.
NOW MY QUESTION:
I live in a relatively old house (build at about 1940): do you guys use when rendering an anti surge power socket, to deliver as stable as possbile power? (https://www.google.nl/search?q=anti+sur ... h&imgdii=_)
Greets!
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
kavorka
I have a UPS (universal power source). It is a battery backup for your computer. It also regulated surges and spikes in power. With a 690 plugged in and rendering, mine will run for about 5 min off of the battery, so if the power goes out for a couple sec, im good to go.
mbetke
Yes you need those extra mainboard power plugs if you have a lot GPU installed. I missed it with my two 580GTX cards too but now with 4 Titans it is very important to plug in the two additional plugs for the pci-e lines.
It is really easy to miss it. I stumbled over this in the manual by accident (which was my luck).
I don't have any extra battery or so. All going well here with german elictricity. My computer used 130KW overall power the last month...expesive business. ;)
PURE3D Visualisierungen
whersmy
That is correct, always add the electricity costs when setting up payment details ;)
Gpu usage is constant 99% now!
