hair-farm + octane render
ch0pper
http://www.hair-farm.com/
Hello I wonder if anybody is using hair farm with octane render?
As I don't want to buy it and find out that it does not work with octane render?
I've sent the manufacturers an email I'm waiting for a reply.
But I thought I would just drop a note into the forum just to see if anybody is you using it.
Thank you I will wait for your reply
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
JuM
i will try for you tomorrow
nildoe
Hi Chopper..it KINDA works :).
It works only if you after modeling/grooming etc..you apply an HairtoPoly WSM Modifier at the top of the stack...of course u have to be careful with with your Card's RAM Limit.
Hairfarm Material does not work though...
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
ch0pper
hi guys i got email back from hair-farm thanks for you replies
Their answer was this
Thank you for your interest in Hair Farm. Your character work is really impressive. It seems like you would certainly benefit from a powerful hair tool like Hair Farm.
Octane does not have direct support for Hair Farm, but you can export hair data from Hair Farm as a spline object or poly object and render using octane. In particular, you can use one of the hair conversion (HairTo) modifiers (HairTo Splines), HairTo Poly, HairTo PolyStrips, or HairTo Instances) or utilities (Hair to Spline Object or Hair to Poly Object). All of these would convert hair strands to a standard object format of 3ds Max, so you can use any tool to export the data..
Also, you can contact octane developers and ask them to provide support for Hair Farm. We have an SDK for renderer developers and it should be quite easy for them to support Hair Farm. This is indeed how V-Ray and Maxwell Render supports Hair Farm.
Best Regards,
Cem Yuksel[/color]
so they are quite happy to give Hair Farm. support to OTOY and SDK for renderer developers let see if we can get OTOY make this happen for MAX?
nildoe
that would be AWESOME!
Elvissuperstar007
I also wrote to the team (hair-farm) 8 months earlier
Olitech
Oh my, that looks incredible already!
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
j7th
ch0pper, thank you, very impressive!
Win 7 x64 | GTX560Ti | Core i7 960 3.2GHz | 24GB RAM
JuM
They should do the same for FumeFX
marilu2011
I also really like the Octane had support Hair and Fur 3ds Max plugin or some hair, sure the staff will work on it soon.
Return to “Autodesk 3Ds Max”
