Unhandled Exception
JNDesign
Hi Paul
Getting this error ...any suggestions
Can you copy and paste the full exception text here pls - I will then investigate. Also, did you get the material or focus picking, or Viewport Navigating, or some other action?
JNDesign
Hi Paul
I cant seem to duplicate the problem.
I think it could have been an issue with overclocking. I have gone back to default settings on the cpu clock and it seems to be ok.
I was getting the error when navigating the view port with material picker on
No probs - if you get it again, remember to copy and paste the text to this thread and write down exactly what you were doing and I'll check it out.
JNDesign
Hi Paul
Its come back (no over clocking)
my comp is
I7 4960X
LGA 2011 (Socket R)
32 Gig of Ram
4 x Titan
I was navigating the scene with Camera only
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at OctaneRenderPlugin.ViewportForm.pictureBox1_MouseDown(Object sender, MouseEventArgs e)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18052 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UIFrameworkInterop
Assembly Version: 0.0.0.0
Win32 Version: 20130308_1515(x64)
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/UIFrameworkInterop.DLL
UIFramework
Assembly Version: 2014.0.0.0
Win32 Version: 2014.0.2013.0308
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/UIFramework.DLL
AdWindows
Assembly Version: 4.0.24.0
Win32 Version: 4.0.24.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AdWindows.DLL
System
Win32 Version: 4.0.30319.18044 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
Win32 Version: 4.0.30319.18060
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
Win32 Version: 4.0.30319.18015 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
UIFrameworkServices
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/UIFrameworkServices.DLL
UIFrameworkRes
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/UIFrameworkRes.DLL
System.Core
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Drawing
Win32 Version: 4.0.30319.18021 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AdApplicationFrame
Win32 Version: 4.0.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AdApplicationFrame.DLL
Win32 Version: 4.0.30319.18047 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AddInManagerUI
Assembly Version: 2013.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddInManagerUI.DLL
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/Microsoft.Expression.Interactions.DLL
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ManagedMC3
Assembly Version: 7.2.0.0
Win32 Version: 7.2.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/ManagedMC3.DLL
APIInterop
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/APIInterop.DLL
RevitAddInUtility
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RevitAddInUtility.DLL
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PackageContentsParser
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/PackageContentsParser.DLL
RevitAPI
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RevitAPI.DLL
AddInManager
Assembly Version: 2012.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddInManager.DLL
StraightSegmentCalculationServers
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/MEPCalculation/StraightSegmentCalculationServers.dll
FittingAndAccessoryCalculationServers
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/MEPCalculation/FittingAndAccessoryCalculationServers.dll
StraightSegmentCalculationServers.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/MEPCalculation/en-US/StraightSegmentCalculationServers.resources.DLL
FittingAndAccessoryCalculationServers.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/MEPCalculation/en-US/FittingAndAccessoryCalculationServers.resources.DLL
AddInJournaling
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddInJournaling.DLL
RevitAPIUI
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RevitAPIUI.DLL
RaaSApplication
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/RaaSForRevit/RaaSApplication.dll
RaaSApplication.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/RaaSForRevit/en-US/RaaSApplication.resources.DLL
AutoLoader
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddIns/AutoLoader/AutoLoader.dll
OctaneRender_for_Revit
Assembly Version: 1.20.1.15
Win32 Version: 1.20.1.15
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/OctaneRender_for_Revit.DLL
Microsoft.GeneratedCode
RevitAPIUIMacrosInterop
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RevitAPIUIMacrosInterop.DLL
SDACommon
Win32 Version: 2014.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/SDACommon.DLL
RevitAPIMacrosInterop
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RevitAPIMacrosInterop.DLL
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AddInJournalEngine
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddInJournalEngine.DLL
AddInJournalClient
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/AddInJournalClient.DLL
DataStorageClientInterop
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/DataStorageClientInterop.DLL
DataStorageClient
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/DataStorageClient.DLL
RS.Common.ClientServer.DataContract
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/RS.Common.ClientServer.DataContract.DLL
MacroHookup
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/MacroHookup.DLL
ConceptualEnergyAnalysisInterop
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/ConceptualEnergyAnalysisInterop.DLL
MessageLoggerInterop
Assembly Version: 1.0.4773.27377
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/MessageLoggerInterop.DLL
MessageLogger
Assembly Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/MessageLogger.DLL
log4net
Assembly Version: 1.2.10.0
Win32 Version: 1.2.10.0
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/log4net.DLL
DBManagedServices
CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20Architecture%202014/DBManagedServices.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Navigating in the Revit viewport, or Viewport Navigating in the Octane Viewport?
JNDesign
Hi Paul
I was navigating in the octane viewport
Problem resolved - pls see STABLE thread.
JNDesign
Many thanks
Return to “Autodesk Revit”
