OctaneRender® for Maya® 1.20.2 - 1.4 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
This is the quick-fix release.
  • Fixed textures path bug.
  • Little improvements in motion blur feature.
Now Octane global settings have "Motion Blur" section. You can enable the Motion Blur there (it will work only in animation render modes). You can set the shutter speed in percentage of frame, and the number of MB samples created for each frame.
To speedup the Motion Blur render you can have this "Number of MB time samples" value overrided for each camera for each frame: Octane camera now has additional keyable attribute "MB time samples override". If this value is "0" - no override to global setting will be made, but if it has the value - this value will be taken.
DOWNLOAD
OctaneRender for Maya 1.20.2 - 1.4 (76.9MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Almost. :-)
It appears that absolute paths still don't work for IES light maps in the octane light node.
Everything else looks good.
T.
TBFX wrote:Almost. :-)
T.
Thanks, will check it.;)
mykola1985
Hi guys,
I'm a max user and I already own octane plugin for max and of course its standalone version. I was thinking of buying
the one for maya (2014), however I would really like to know a couple of things before I buy it:
would you be so kind to answer my questions?
1) when I import to maya the alembic pipeline GPU cache, is octane able to render it in maya?
2) how fast maya's octane plugin is compared to the one in max version (in the same scene)?
3) does it have the movable proxy option?
4) will it render Miarmy or Goleam (crowd plugin)?
5) can it render hair and fur?
thank you guys!
I hope somebody will post me a reply.
SORRY FOR THE OFFTOPIC!
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
ciboulot
Hi Jimstar,
thanks for the update.
One question. I can't manage to get the MB working.
My objects are "movable proxies", the render is animation full or movable proxies, and motion blur is on in the render globals.
Nothing happens. Am I missing something?
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
TBFX
ciboulot wrote:Hi Jimstar,
Have you tried to batch render the scene? The motion blur does not show up in an interactive single frame render as the plugin needs to render several sub frames for each actual frame and then average them together.
T.
TBFX
Hi mykola1985,
See my answers below.
mykola1985 wrote:1) when I import to maya the alembic pipeline GPU cache, is octane able to render it in maya?
Yes alembic geo will render, I haven't tried the GPU cache but it will most likely work, though if you are rendering with Octane you probably don't want to be filling up Vram with geo cache.
mykola1985 wrote:2) how fast maya's octane plugin is compared to the one in max version (in the same scene)?
I haven't used Octane for Max but the actual rendering should be identical as they use exactly the same engine. There could be differences in the scene translating and transfer to the GPU's though.
mykola1985 wrote:3) does it have the movable proxy option?
Yes.
mykola1985 wrote:4) will it render Miarmy or Goleam (crowd plugin)?
I don't know, I don't have either of those but if you can display normal Maya poly geometry in the viewport it will be sent to the GPU and render.
mykola1985 wrote:5) can it render hair and fur?
Only by converting to polygon geometry. The Octane engine does not support any other primitives for now.
Hope that helped.
T.
mykola1985
Thank you a lot for the reply TBFX!
I'm in debt to you!! ;)
Sorry for the offtopic Again!
ciboulot
Thanks for your replies TBFX.
I will check that right now.
suvakas
Hey guys,
How do you control the focal depth with camera aim locator?
I'm new to Maya and I can't get it to work. Or is there another way to animate focal depth in Maya?
Suv
Return to “Autodesk Maya”
