Pre23 v4 - black vertical line in Render Viewport
- watchyour6
No change to driver or hardware, since the previous beta version. The black vertical did not show up in previous beta version. Saved image file has the line, also. This sample was at 1024x768 resolution. Is there a way to get rid of it?
Win 7 x64 | 2x GTX460 2GB + GeForce 8600 GT 256MB | Quad 2.93GHz | 8GB
- watchyour6
I see. Thanks. But multi cards are recommended here in many threads.
I have the same problem, both with single and dual graphics cards.
However, they're more or less visible depending on the resolution.
For instance at the default 1024x512 the lines are clearly visible, but if I change to 980x512 they almost disappear (seems to depend a bit on the scene or lighting).
I'm using Nvidia driver version 258.96.
Intel i7 930 2.8 GHz | 24 GB | GeForce GTX 980 Ti, 6 GB | Windows 7 Pro 64-bit | Houdini FX 17.5 | http://techie.se
