OctaneRender™ for Blender 1.20.2 - 2.4 beta Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • LiveDB material is now set to current active Blender material.
  • Simple workaround of nodes arrangement in node-editor after getting them from LiveDB. Nothing complex, as this is completely the Blender node-editor's responsibility to have the "Arrange nodes" function, so I will not spend too much worktime on some more complicated things here...
  • Fixed the bug affecting RGB colors of materials taken from LiveDB.
  • Added extract command line key to Blender installer.
  • Minor improvements and bug fixes...
Installation:
- Just run the installer.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v2.4 beta Linux (128MB autoinstaller file)
Toast
Nice, works very well, so far.
kaiwas
Thank`s!
All works properly, so do not write anything :D
kaiwas
does not work render region (border)
afecelis
Feels like the Linux version works faster than windows'. The driver detected my card as a GK104. First time it shows up in blender like that :P
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
grimm
Just doing some more playing around today and noticed that OctaneServer doesn't appear to respond to the ctrl-C signal. If I want to stop it, I have to kill it. When it crashes with the executed illegal instruction error it doesn't stop either and I have to kill it then too. ctrl-C doesn't do anything.
If it helps with the executed illegal instruction bug, I saw today when I quit Blender it crashed. But I'm not sure if it crashed before I quit or because I did quit?
Alesk
Impossible to install it here, double clicking the file doesn't do anything :(
Running on Ubuntu 12.04 lts, any idea or tips to share please ?
Edit : ok found... I had to type in terminal
./octane_blender_1.20.2-2.4.run -i
to install it
now my second problem : run the octane server as daemon, the provided command line doesn't seems to work :(
mib2berlin
Hi, try this:
./OctaneServer &
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Alesk
Thanks ! :D
Do I have to do it manually each time I reboot ? Is there any simple way to automatically do it at startup ?
I'm no linux guru (as you may have noticed)... I've googled this question and only found complicated (for me) answers :(
Please a last little help to make my day :mrgreen:
Toast
That depends a little bit on distribution / desktop environment.
Easiest one:
If you're using (x)ubuntu, open a terminal and enter "gnome-session-properties", you should see a menu where you can create new autostarts. You don't need to use the "&" in here, thats only to start a programm in the background from the terminal.
Return to “Blender”
