Scifi corridor - My first light emmiter test
This is a scene I did in maya some time ago. Cooked about 20 minutes with pathtracing, maxdepth set to 4 and 1920x1200 render resolution on a 2gb Geforce 460 GTX. There is no environment lighting in the scene. The "Windows" are polygon objects atm. The problem I'm having with this scene is that the lighting is too uniform. Almost the same as just using direct lighting with a white background. I need to figure out how to get the areas close to the light sources a bit brighter and the the areas further away a bit darkes. There is also a color difference in color temperature in the windows lights and the ceiling and wall lights that isn't coming across.
Win 7 64 | Geforce GTX780 | i7 3930k| 32GB
Not Even 1 piece of Wookie Hair to be found!
MSI NF980-G65 AM3 NVIDIA nForce 980a AMD Motherboard - AMD Athlon II X4 620 (Overclocked to 3.2ghz)
(2)GTX460's, (1)BFG gtx260, OCZ 60GB SSD, KINGWIN 1000W Power, HAF 932 Full Tower, XP64
Octane V1 - 2.46 - CUDA 4.11 - OBJ's from Rhino4
The lighting in such scenes is always uniform / bright, unless the spaceship has been already attacked / something went terribly wrong, and Aliens are waiting at the end of the corridor.
Maybe remove / half open the door, copypaste the section, and make that part semi-dark / different illumination...
edit: and scale the floor UVs - those raised "buttons" should be smaller.
cgmo.net
cgmo.net
Absolutely right!matej wrote:The lighting in such scenes is always uniform / bright, unless the spaceship has been already attacked / something went terribly wrong, and Aliens are waiting at the end of the corridor.![]()
Nothing better than an explosive decompression to spice your lighting up a bit.
Antec 300 Casing/Windows 7 ultimate 64/i7 920/ ASUS p6T/ 6GB RAM/ Sparkle GTX470 1.2GB & Asus GeForce 8800GTs 512mb
Warning ! No droid allowed beyond this point !
Humans, please wear felt pads !
Nice scene !
Nice scene !
