PB with material change
BorderLine
Hi team !
I've a problem with IPR, and render F9 same, ! If i change - click on a texture when IPR run, LW stop and no response.
Thanks in advance
juanjgon
BorderLine wrote:Hi team !
Thanks in advance
I don't understand well your problem ... could you explain the issue a little better, or post a screen grab with your setup when LW hangs?
BorderLine
Hi and sorry for my english,
My problem is the same as already reported in the LW forum I think.
If I start IPR and I click on a texture in the Surface Editor, LW hangs and becomes unresponsive.
Thanks in advance
juanjgon
Here it works fine. I can click o the "T" texture buttons of surface editor with IPR opened without problems ... Octane doesn't render the "T" textures, but LW doesn't hang.
Is this the problem you have?
BorderLine
Thanks !
No, problem when i click on a Surface name for change, for example, a color.
LW and IPR stop and hang.
juanjgon
I never see something like that.
So, you enable IPR, open the Surface Editor and when you click over a surface name LW hangs?
Can you post a screen grab when LW stops?, or send to me a scene with this problem?
BorderLine
Ok !
I'm in production dead line here. When i've 5 minuts, i became with my scene.
Thanks very much !
Rapid and pro
BorderLine
OK !
Try this please :
Open scene
Acivate Octane plugins
Start IPR
Open Editor (Octane)
Add Sunsky environnement
Add pathtracing Kernel
Open Surface Editor
Find SURFACE_PEINTURE_MATE
Click on color vignette
Move slider color for change
Blocked !
IPR stop and I must closed LW
This is a FBX file, not cleaned, unmodified imported into Modeler and transferred into the Layout.
The camera is adjusted and that's all.
Thanks in advance
PS: Where can i send the zip file please ? 87 Mo
Franck
juanjgon
You can send it to [email protected]
BorderLine
Ok ! Send you with DropBox.
In a few minutes !
Return to “Lightwave 3D”
