I would like to use the info channel/Material ID pass of octane.
Somehow there are already Material IDs in the octane pass although I didn´t set
any in the 3dsmax Material editor ID settings.
Changes to the 3dsmax Material IDs (1-15) don´t effect the octane info channel render.
Am I missing something? Does octane has its own material ID settings? If that´s the case,
where can I change them?
Material ID selections
I would like to use the Info-pass too.
If its not possible to integrate it in the render elements, then it would be helpful to have a button in the render-setup that triggers a script or whatever to render a predefined info-pass after the actual rendering. may be even with lower settings tio speed up things.
that would be really helpful.
