Backplate
ronjart
I was wondering if anyone had a good workflow for creating a backplate. Doing it in post can be tricky since the opacity map on leafs (for example) doesn't render out in Material ID pass. Doing an emissive diffuse material on a plane can be a little cumbersome.
I'm thinking of Vray and the two dome light approach (one for lighting and one for background image). I've tried to make a simple sphere and play with the object properties like "don't cast shadow" etc. with no results.
Any ideas?
Return to “Autodesk 3Ds Max”
