Brushed Metal - Need Help Please!
cgpanda
Hi everybody, first of all i want to thank you in advance for trying to help me.
So i'm trying to create a realistic possible brushed wedding bands.
here is a picture of it.
Can anyone help me with this? I did create the material, and the lighting,..i do get good results, but i can not get results like above. Is it possible to get that realistic results with octane?
Cheers cgpanda
Silverwing
You can try using a really high res bump map for the "scratches" of the brushed metal.
If you look et it physically those brushes are tiny scratches alongside the ring.
So if you use a map that produces this tiny bump pattern over the surface it should look right.
I have used this method to render this:
http://silverwing-vfx.de/3D-Stills/Cylinders.jpg
Also a detailed description could be found in the Octane thread:
http://render.otoy.com/forum/viewtopic. ... silverwing
Silverwing
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
