Hello
Maybe I'm blind, but I'm looking for the gradient.
I wanted to colour grass. Down the grass blade in a bright green, then continue to the point of becoming darker. Above the tip may be yellowish brown.
I can forgive but so far only a shade...
Gradient Materialeditor
you can use most c4d shaders, these are converted to textures and appliedRudi wrote:Hello
answer is there:Rudi wrote:Fact...
Why didn't it?
Maybe because I used levels? MH... THX
http://render.otoy.com/manuals/Cinema4D/?page_id=629
I think that there still a small problem is, because I do not get the texture size on 2048x2048 firmly to put.
Over and over again this value on is put back 512x512 or the field is empty.
I must observe this sometimes. Or must this value be put over and over again anew if one restarts the OR?
you must restart render to see updates, it not support realtime changes as octane textures. Also sizeRudi wrote:I think that there still a small problem is, because I do not get the texture size on 2048x2048 firmly to put.
I put Settings-> Shader to Texture-> Size 512 on 2048, then I finish the OR and restart him, this setting is empty. Neither 512, nor in 2048 stands now there. He forgets not only the setting, he leaves them empty...
With the materials it is even worse, but this is another subject, but extremely irritatingly, there toilfully.
In addition I open own subject.
