OctaneRender for Rhino Roadmap
Hi, I thought I would outline some of the changes that are coming in the next release.
Firstly, the material system is changing so that an Octane material is just another type of Rhino material. When you render in Octane, both Octane and non-Octane materials will render in the viewport - the Octane ones you will be able to edit the Octane node structure (as you can currently). So the Materials tab will be removed, and Octane material editing will happen in the Rhino Material panel. This change means your current Octane materials will be lost for existing scene, since the new and current systems are totally different from each other.
There are a range of follow-on changes from the above change. For example, the ground plane material will now render correctly in Octane.
The other exciting change is support for Edge Softening, Curve Piping and Displacement. The geometry generated from all the features in Rhino will now be rendering in Octane. The image below shows the Viewport for both Rhino and Octane with these effects (and you can see how the new material system has rendered each material correctly in both viewports too).
There are a host of other minor fixes (alpha channel support in the Rhino render panel, etc) which will be made to the next release too.
The attachment rhino render effects.png is no longer available
gabrielefx
great!
Daniel79
NOOOO, Fantastic!!!!
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
v-cube
:D
Paul you are the man !
thanks
Andy
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Refracty
sweet
jitendra
That will be great.
Best Regards, Jitendra
newske
Fantastic. Wonderful job Paul.
*nudge* proxy instance scale referencing :)
Can't wait.
Octane for Rhino | Windows 8.1 x64 | i7-3820 OC | GTX970 4GB OC & GTX 560 Ti 1GB OC | 32GB DDR3
Closer integration of the Rhino block instances is definitely something that will happen - probably the release after the material integration release.
vanhage
Great Work Paul. Keep it up!
Win 8 64 | 2X Geforce GTX680 | i7-3770K Ivy Bridge 3.5GHz | 32GB
Bendbox
This is terrific news! The material system overhaul will greatly increase efficiency and be less confusing to new users as well. Paul, you rock!
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Return to “Rhinoceros 3D”
