Hi
Just a quick question.
If I have a material that uses an image texture, is it then possible to adjust lightness, hue to that image inside 3ds max - or do I have to open the texture in photoshop and add the changes in here?
Jorgensen
adjusting a texture
- MaTtY631990
You can make a texture lighter/darker with a color correction node placed first in your diffuse slot first with the map loaded into this. The only thing you cannot alter at the moment is hue.
Matt
Matt
Thank Matt
Very appreciated.
Thanks.
Very appreciated.
Thanks.
