Portals
JNDesign
Hi Paul
Are lighting portals possible in Revit plugin?
cheers
Yes, simply change the material type to "portal". IMO, using the "fake_shadows" on a "specular" material is better suited to Revit, since Revit will already have the cavity (from the window geometry).
JNDesign
hi Paul
Could you please clarify what you mean by IMO
Also, do I create a material called portal? as it doesn't exist in the materials?
thanks and sorry for the lame questions
IMO = "In my opinion"
There is a portal tutorial in the resources forum here.
For Revit, if you were going to use a portal, I /think/ you would have a plain with a glass window, then set the material type of the glass in that window to "portal". But I think (and there are people here with far more expertise in this area than me), you are better off leaving the glass material as specular with "fake_shadows" on, and reduce the opacity (or increase the kernel indirect light importance) if the lighting coming through the glass is causing too much graininess.
I'm not certain, but I suspect the "fake_shadows" pin in the specular material makes the portal material less commonly used - but hopefully people with more knowledge than I on this may comment.
JNDesign
Thanks Paul
Been meaning to ask if the plugin is a "full octane render or has it been stripped and minimised for application like Revit"
just a general knowledge for me.
cheers
It's the full renderer. Same speed, capacity, nodes, etc. I think the gradient node is about the only thing that's in Standalone but not in the plugins.
JNDesign
thanks
Return to “Autodesk Revit”
