In the last 2.3 (testing version) i have a strange crash.
If i load scenes *.ocs every thing work fine.
If i try to import a OBJ the program freeze and immediately crash. How i can show to you this bug? There is log or something to send you to discover the reason of this? Thank you very much!
Found strange crash during OBJ import
Post your .obj file here (if it's not too big).
You should also write your system software & hardware specs in your signature, so its easier to pinpoint problems.
cgmo.net
cgmo.net
yes, post a zip with the obj & mtl here and we'll look at it
Regards
/M
Regards
/M
I have the same ... 8800GT+XP32 ... obj imported from sketchupyashugan wrote:In the last 2.3 (testing version) i have a strange crash.
The crsah din't happen during the OBj import,the program crash before to open any window that allow me to pick any file. It crash when i do "import mesh" and i crahs exactly inside the OBJ mesh import preferences windows.
So is not a question of the kind of obj, because i'm not able to load any file.
The workflow is this: Load octane 2.3 beta, i do "import wavefront obj" , the shell appear, i press OK, the program freeze and after crash.
Here my specs:
Processor: Interl i7 cpu 2.93
8.00 giga of ram.
64 bit windows 7
Ge force GTX460
But i suppose that without some kind of log is hard understand why ths crash hannpe.
Thank you!
Here my specs:
8.00 giga of ram.
64 bit windows 7
Ge force GTX460
Thank you!
Could it be either your file or the path to it has foreign characters like ë,à or things like that ? Octane didn't learn to speak them yet, unfortunately.
Try using just simple ascii names, both for obj/mtl and texture names.
yes but it crashes when it's chosen - after you press OK before choosing FileNostromo wrote:Could it be either your file or the path to it has foreign characters like ë,à or things like that ? Octane didn't learn to speak them yet, unfortunately.
I not chosen anything yet so there should be trouble with the file name, folder, etc..
It crash before i choose any file.
I do " import obj" than the shell appeat with imprt preferences.
i presso ok, ad it crash, BEFORE that i can choose or browse any file in any folder.
If Octan write a log or something similar i can send it to you
radiance wrote:please attach and example (zipped),
and make sure you don't have non ascii characters in the path/directories where the file is...
Radiance
