Tested with the Phantom Scatter Beta
scottbroad
I have had a go with the Beta of Phantom Scatter - a program being developed by Guus Thissen - http://render.otoy.com/forum/viewtopic.php?f=9&t=33791.
A typical method could be to export the Revit Toposurface as an OBJ file and create a CSV scatter file in Phantom Scatter from this OBJ file - the scatter objects used are not important.
Back in Revit add a component for the object to be scattered, any graphics will do. With the Octane Render Revit plugin open select the component and set the material as a Proxy object. In the Geometry Proxy Details dialogue select the Scatter CSV file from Phantom Scatter.
You should now have the Proxy object scattered over the Revit Toposurface ...
Clive Broadhurst
Win 10-64bit, i7-3770K, 16Gb, GTX970
Revit 2015, Blender
Return to “Autodesk Revit”
