I've only been using Octane for a few days so please go easy on me if this is a simple question.
Is there any way of seeing the full extent of a render? i.e. I have a render which is 4000x3000 pixels and I want to see exactly what the camera is seeing. At the moment all I can get is a 1:1 ratio view of as much of the image a will fit into the view. This is not very useful for getting the framing accurate.
Hope that sort of made sense.
Full image view
Hold Ctrl + mouse scroll to zoom in and out.
PS: Please add your OS and Hardware Configuration in your signature, it makes it easier for us to help you analyze problems. Example: Win XP 32 | Geforce GTX260 | Quad 2.66GHz | 4GB
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
CGsociety gallery
My portfolio
Web site
- Jaberwocky
Not sure if this is the right place to post this suggestion for a future release.Anyways here goes.Re the above for anyone using a 2 monitor system is there anyway to have the Render Viewport/Graph editor/Node inspector and project bars as undockable/floating so that you can tear them off and put them across on the 2nd screen.This would mean you'd be able to enlarge all of the viewports and use both screens real estates.
this is quite timeconsuming so it won't be for v1.0...Jaberwocky wrote:Not sure if this is the right place to post this suggestion for a future release.Anyways here goes.Re the above for anyone using a 2 monitor system is there anyway to have the Render Viewport/Graph editor/Node inspector and project bars as undockable/floating so that you can tear them off and put them across on the 2nd screen.This would mean you'd be able to enlarge all of the viewports and use both screens real estates.
Radiance
