I'm a brand new customer. After a very convincing demo version 1.20 I purchased the version 1.20a today. The test scene I created for the demo version 1.20 is now very grainy under the purchased version 1.20a when using an hdri.
This was the demo that rendered smooth: OctaneRender_demo_1_20_win64.exe
This is what I purchased today and renders grainy: OctaneRender_1_20a_win64.exe
I am using Windows 7 and 3ds max 2012 64bit.
The amount of bright "snow pixels" increase the longer I wait.
Also the entire "Imager" rollout doesn't work anymore. No difference no matter which values I put in.
It can easily be that I missed something as I am very new to this engine.
Any clues what I am doing wrong?
Andre
Demo Version grain free - Purchased not ?
- MaTtY631990
This might be unlikely but you can check to see if the importance sampling option is switched on under 1.20a. With this turned off your renders could take longer. Also let me understand, changing exposure, ISO etc has no effect on your render. Also no idea what is effecting the imager, but I would try the option of keeping the demo and the commercial version on and compare them if necessary might be best way to see what settings are different. If it does not work then do a clean install with the commercial version.
Matt
Matt
Thanks for the reply!
I rebooted my machine and now the Imager parameters work but I still have the grain which wasn't there in the demo version. I want to use Octane in 3ds max only, not the standalone. It also seems to be that the entire "Post Processing" rollout is not in the UI anymore? It certainly was in the demo version. I'm getting a bit confused here.
The demo version dlls in the 3ds max folder were overwritten by the purchased version.
I don't have the setting "importance sampling" in the 3ds max UI.
And where do I get the Max2Octane Script? The Manual just assumes you have it but doesn't tell me where to find it. It wasn;t included in the downloads.
What do you mean "star filter"? May be post processing?ACantarel wrote:Thanks for the reply!
I rebooted my machine and now the Imager parameters work but I still have the grain which wasn't there in the demo version. I want to use Octane in 3ds max only, not the standalone. It also seems to be stuff like the star filter of the sun etc is not in the UI anymore? It certainly was in the demo version. I'm getting a bit confused and the manual doesn't cover the UI inside 3ds max if I saw this correctly.
I don;t have the setting "importance sampling" in the 3ds max UI.
importance sampling is an option of octane environment texture
Hmm I am slowly getting a bit frustrated :-/ After 3 hours I still wasn't able to find the max2octane script download which imo should have been included in the installation package. And with the post processing rollout gone I have a render engine that can't do in 3ds max what the demo can do which led to the purchase. I never wanted to use the standalone (which now I semm to have to with the post processing rollout gone), I want to stay in 3ds max.
Maybe it's still my user error which I know is the most common issue when I did support for another render engine for several years.
Could you show your octane render settings?ACantarel wrote:Oh sorry I was just in the process of editing my last reply when you started replying. I meant the Post Processing rollout. Star filter was just a wrong term I wrongfully remembered. Glare Ray was the right term.
Ups, that is my fault.
For some reason users get links to old version 1.10 after purchasing.
you can download new one here
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.20.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.20.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.20.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.20.zip (50MB ZIP File)
