How about R12?
mantra
subj ;)
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
abstrax
mantra wrote:subj ;)
Yup, the next version will run on R12, too. I didn't have much time the last days, so 0.10 is not finished yet, but I hope it's not far away anymore.
Does anyone already have the R12?
Marcus
mantra
if you need for tests, u can download from http://www.maxon.net full worked demo
u can make it in the python also
MY WORKS
abstrax
mantra wrote:if you need for tests, u can download from http://www.maxon.net full worked demo
I've got R12 running here, that's no problem, but I will not rewrite the exporter in Python. Two reasons for that: Speed and backwards compatibility.
I was just curious, if actually someone uses already the R12 ;)
Marcus
mesut
abstrax wrote:...
Marcus
yes.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
e3di
I'm running R12 as well..
abstrax
Hi all,
just to let you know: I have starting on the work to make the exporter code compatible with R12. As it's a tedious process, I'm sharing my dev time between new feature things and the R12 port. The reason, why porting the code to R12 takes that long is, that I want to keep it backwards compatible back to R9.6, which means that I have to put in fallback code for the older versions. Otherwise it would probably be be done already.
Marcus
mantra
now i'm using r12 too!
MY WORKS
abstrax
I'm now half way through the port ... ;)
Marcus
