let me get this straight
prehabitat
I'm a step closer to a solution on my headless, VNC controlled remote media server/render slave idea: about to test the proof of concept on some unused hardware I've got lying around (haha)
Potentially have a couple of GPU rendering hardware limitation hurdles to overcome:
A render 'Scene' (everything with the visible FOV of the virtual render camera) and its size in VRAM is a factor of geometry being calculated, plus the uncompressed size of all the textures visible: I am very new to creative use of textures but you can use many 4k textures within one scene (4000pixel x 4000pixel? this seems massive for a 'typical surface image' i.e. texture??)
Anyway, these 4k textures are uncompressed at 100mb or so, (2k about 30mb?) and an large-ish architectural scene (external) can be 7-900mb just of geometry. My current video card is only 1.5gb...
Rendering software 'voxeling' is very cpu & more importantly memory intensive for about 1-5 minutes: but then cpu memory not tested at all. HOWEVER, the rearranging of the geometry & texture data so it can be processed by the GPU costs about 4x the VRAM scene size in RAM: i.e., 1.5gb video card = 6gb Voxeling cost (can be swapped out, but costs ALOT of time - and time saving is the whole reason to use GPU rendering) - also: its a parallel computing model: so the 6gb cost can feed as many 1.5gb GPU's as you have connected?
Current test system is is a [email protected], 8gb ram(1200mhz), SSD, with two x16 pcie slots, 1xGTX580 1.5gb (single gpu) 1x monitor GPU (for display only, not rendering).
Hardware/Upgrade problem/considerations:
**If 1.5gb is always enough for my typical GPU rendering jobs then I can sell some surplus stuff and buy two GTX590's (2x gtx580's on the one pcb, w/ 1.5gb each)
Upgrade path: later can buy a cheap-ish (haha) QUAD SLI capable motherboard +CPU&RAM to suite: which can allow me 4x gtx590's for a 8x setup.
**if 1.5gb isn't enough I need to sell my gtx580 1.5gb and buy two gtx580 3gb's - but then I run into the RAM limitation/setback which means I probably need to upgrade M/B, CPU & RAM anyway: would still buy 4xPCI-E x16 capable motherboard and could get 2 more gtx580's for 4x setup.
I suppose firstly I'm looking for corrections on the above statements;
and secondly a resource of arch-vis renders (internal & external) which have been rendered with alot of massive textures (ie 1.5gb VRAM-3gb VRAM cost) and annotated as such (so I can compare them to my current outputs and make up my mind if I'm willing to suffer the limitation of 1.5gb VRAM for the sake of speed...
Even if someone here could supply two test renders(arch pref.): one at 2.5gb VRAM cost, and one at 1.25gb VRAM cost for comparison?
Thanks for your help!
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
Nuge
Note GTX590 have 1.5g Vram shared between the 2 GPUs so effectivly you get 0.75 G Vram for each GPU
C4D R19 / Win 10 / 7 GTX 1080
prehabitat
Hmmm, I've only seen them with 3gb (1.5gb per GPU) ?
the 3gb version is the one I would get anyway...
FooZe
Just some TMI details:
A 4000x4000 texture (LDR) will consume 62,500KB in octane.
Another thing to note is the render target (place where the HDR rendering results are stored)
This also takes up VRAM and is dependent on the resolution your rendering at.
(this is referred to as the "film buffer" in the File -> Preferences -> CUDA Devices tab)
A 4000x4000 film buffer is about 306MB
8192x8192 is 1.3GB
So if you want high-res renders you also need a lot of VRAM.
With a test of a 6.19 million triangle scene (732MB of geometry, simple bunch of high poly spheres) Octane 1.2 peaks at about 2.2GB of System ram usage. It shouldn't make any significant difference if you are rendering with more than one card. This takes about 32 seconds on my machine to compile and your CPU is faster than mine :)
Chris.
prehabitat
Beginning to think I should get 1x gtx580 3gb & 1x gtx590 3gb (1.5+1.5) for now,
I can use the 3gb for display, and process my smaller presentation graphics really fast(USING 580+590): and when I occasionally need something monsterous (comparitively) I can just tolerate the slower speed...
Seen a few others on here with 3x590+580: its starting to make sense!
