OctaneRender for Revit Beta 1.20.1 [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit, build 1.20.1 (STABLE RELEASE). This version is compiled against Octane 1.20.1, so see the requirements for that build regarding compatibility with your video card.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
Change Log from release 1.20a
- Missing OBJ proxy files which are duplicates will only display the warning message once
- Rectified issue setting a proxy rotation when the host object has no rotation parameter
- Added copy and paste buttons for proxies
- Fixed issue when Revit emitter materials were not being correctly converted to Octane diffuse emitters (Revit 2014 only)
For more information...
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Revit 2014 1.20.1 beta (64 bit)
- OctaneRender for Revit 2013 1.20.1 beta (64 bit)
- OctaneRender for Revit 2012 1.20.1 beta (64 bit)
JNDesign
really silly question Paul
can we just run the install or do need to uninstall the previous plugin?
Just re-run the installer - it installs over the top of the previous version.
WestCAD
downloaded latest plug-in.....1.20.1.10
previous version was 1.20a5
The octane symbol doesn't appear in plug-in
The plug-in still works
Windows 7 64bit, I7 [email protected] GHz 12gb Ram, Quadro 600
Autodesk Building Design Suite Premium 2015
Yes - I just found that too - fixing it right now.
WestCAD
just tried latest plug-in (1.20.1.10) on jndesign's test file and the lights work fine
I have refreshed the installers at the top of this thread. Pls re-download and install for.....
1.20.1.11
- Rectified issue where the Octane icon was not being displayed on the Revit Addin toolbar.
1.20.1.12
- Fixed issue where loading a very large scene would raise an exception.
- Added a "Maximum Number of Polygons" configuration item. Increase this number if you receive a warning that the scene has exceed the limit number of polygons.
1.20.1.14
- Russian (and other non-English Revit version) compatibility fixed
I have also changed this version from TEST candidate to STABLE.
I have refreshed the 2014 installer at the top of this thread. If people on 2012 or 2013 need these changes, pls let me know.
1.20.1.15
- LiveDB categories change to enable loading of Otoy category materials
- Moved release number from the window title to the Activation tab
Return to “Autodesk Revit”
