Octane Viewport not Same as revit Viewport
JNDesign
Hi
When I open my viewport in in Octane plugin (revit 2014), the view is smaller than of the revit viewport
(ie not everything is visible)
Any fix or am I doing something wrong
win 7 64
dell precision dual zeon 3ghz (12cores 24 threads)
quardro 600
thanks in advance
Hi - the Octane "fov" is set to the Revit default fov (50). If you change the fov in Revit via adjusting the view boarders, simply modify to Octane "fov" slider to match to new Revit view size. In general, I leave the Revit view WIDTH the same, and adjust the HEIGHT to cahnge the aspect ratio of the Revit view - that way to horizontal "fov" stays at 50.
I hope that makes sense. I will update the manual at http://render.otoy.com/manuals/Revit/?page_id=67 to provide more detail in this.
JNDesign
many thanks
Return to “Autodesk Revit”
