Texture updating
Dave_Yu
I noticed that when I make adjustments of a texture in photoshop saved with the same filename, it would be good to have a update texture button.
Textures don't seen to be flushed from memory even if I reload the adjusted texture. Workaround is to load up another texture and then reload the original adjusted texture.
Reality4
+1
HHbomb
Chris
1+ indeed. It would be great if this was done automatically
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
Dave_Yu
Also sometimes the texture being used will be locked by max/octane and cannot be overwritten in Photoshop. So the workaround is have to save textures with different filename eg texture_v2.xxx
Return to “Autodesk 3Ds Max”
