Dirt Map with C4D Plugin
EdCast
Having issues getting dirt texture to work.
I tried loading dirt into the Diffuse/Bump/Normal channel. I don't see a difference...
What am I doing wrong?
I'm using the plugin, not Octane standalone.
Any tutorials for the C4D plugin itself? (Not the standalone version)
Is there a texture I can download from the Live DB as an example?
Thanks.
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
FooZe
The best option for this is to use a mix material with the mix input as a dirt texture:
EdCast
Thanks! :)
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
tegatwork
I'm currently playing with Mixtexture in Diffuse Channel, in order to get dirt on my materials.
As soon as I'm using a MixTexture or MixMaterial, the material is no longer visible in Cinema4D's view. Is there a way to resolve that?
tegatwork wrote:Hi,
did you put any texture to amount slot? Can you show me something?
tegatwork
Yes, i did pût te Dirt in the amount port. It's working very Well in the octane view.
tegatwork
Aoktar, this is a screenshot about how I'm using the Dirt, and how the mix material prevent me to see my materials in the Cinema4D view.
Hope it will help you to find where I may have made a mistake...
I'm running Octane Render 0.8.1b SDK 1.2 with Cinema4D R14 on Win7, with 2 GTX Titan.
did you check the option on octane settings?
"Use Octane for Opengl...."
tegatwork
you're the best ! thanks a lot
