Trace Back Error
morphious2013
Getting this error upon initiating Octane Plugin.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 73, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3993, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 102, in CreateNodesFromPoserScene
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 1143, in fillOctaneMaterialsArray
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 1914, in createOctaneMaterial
AttributeError: 'NoneType' object has no attribute 'Value'
Is this an object in the scene that is causing the error? Also, after that the "Converting Material" window stays open forever, and if I close it, open Octane view port, no textures are rendering. Also, in the Materials Tab, nothing is there. Oh Also, I'm using 2014, but traceback references 2012.
Thanks.
From the traceback info, it looks like it is a corrupt Poser material - potentially a bump map issue.
Yes, it is likely caused by a particular object in the scene.
Can you email or post the octaneplugin.log file pls, and I can tell you which material or object is causing the issue.
morphious2013
Yep. Hair object on V4. Deleted it, replaced it. Works fine. How can I determine if a object or the objects material is corrupt? Renders fine in Poser Firefly.
Any geometry which raises an exception will generally be listed as the last item in the octaneplug.log file.
Return to “Poser”
