OctaneRender for Revit Beta 1.20a [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit, build 1.20a (STABLE RELEASE). This version is compiled against Octane 1.20, so see the requirements for that build regarding compatibility with your video card.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
Change Log from release X.XXa
- N/A
For more information...
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Revit 2014 1.20a beta (64 bit)
- OctaneRender for Revit 2013 1.20a beta (64 bit)
- OctaneRender for Revit 2012 1.20a beta (64 bit)
Pls note that the above installers are current the same version as the Otoy store. If and when revisions are make, the installers above will be the revised version.
perro_abombao
great....demo version when? :)
PD...lights converts in black body emitters...IES patterns as well?????
demo version when?
Yes - in a couple of weeks time.
Yes - http://render.otoy.com/manuals/Revit/?page_id=79. Once you have an IES light setup, export the material for later use on other lights, or save as a Favourite for even quicker application to other materials.
perro_abombao
Super!!!! 8-)
I have posted a new version. Download from the links at the top of this thread.
1.20a5
- Detects when there is no "Project Browser" scene element (which may happen on non-English version of Revit) and gives a warning rather than raising an exception. If you get this warning, pls tell me the version of Revit you are running, and the name of the "Project Browser".
- Added "arborescence du project" as the project browser location to attempt to rectify the issue with locating the project browser element on the French version of Revit
- Added additional diagnostic information if the plugin is unable to be authenticated
Curcis
Hi everybody,
here is my first test: :D
http://screencast.com/t/aoVdgrzbP
What way to atempt changing the maping of Octane material?
regards
Nice work!
If you are using Revit 2014, the UV mapping will be as per the geometry - so you can adjust the Octane material "image" -> "diffuse" -> "scale" to enlarge/reduce the texture. Otoy have indicated that texture rotation is probable for Octane 1.5, which will give you more options. Also, if you are using the LiveDB materials, you can adjust the texturemap scale in the "Settings".
Does that answer your question?
Sauger
Plugin works great :D.
But when try to add a csv file I get an error.
Same file works fine in Archicad plugin, and standalone.
Revit 2014/Win7 Ultimate64.
System.FormatException: Input string was not in a correct format.
at System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Single.Parse(String s)
at OctaneRenderPlugin.ProxyInfo.LoadCsv()
at OctaneRenderPlugin.ProxyForm.csvSelectFileButton_Click(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
3x I7/16gb/GTX570/XFX5870/GTX Titan
Hi Sauger - can you pls post here or email ([email protected]) the csv file, and I will rectify the issue.
Return to “Autodesk Revit”
