Instancing with relative paths
kavorka
I have a setup with dropbox so I can set something up and then render different views from multiple computers at the same time very easily. What I just noticed is that the actual dropbox file path is different for each comp because of the different usernames. Now, when I open a .ocs, it just loads everything no problem, except the scatter file. I need to open the scatter file using the new path. So, I am guessing that for some reason, those scatter files arnt using relative paths?
The scatter files are in the same folder as the .ocs files.
