Rayepsilon...rrprob
cristian.tumiati
Sorry but...what is these two parameters in the pathtracing node?
Another question...the max depht is only for the reflection refraction ...or?
win7 64 | Geforce GTX 560 + 2 x GEforce GTX 670 4GB | i7 3930K @ 3.20 GHz 3.20 GHz | 32GB ram
radiance
rayepsilon is the distance to offset new rays, you should'nt change it.
rrprob neither, it's the probability of ending paths.
maxdepth is the maximum depth of paths. (this is limited by the RR though)
best not touch these :)
Radiance
d.welshhons
radiance wrote:.maxdepth is the maximum depth of paths. (this is limited by the RR though) best not touch these :)
Radiance
So is maxdepth how many bounces [or paths] the raytracing will calculate? If it shouldn't be adjusted then maybe that function should have a static setting as it would cut down on code. In fact if all three of the functions mentioned above should be left as is, making them static would be optimal from a coders point of view to keep the overall bloat down.
System Specs: Windows XP Pro x64, ASUS P5QL PRO, Intel Core 2 Quad 3.00 Ghz, 7 Gb Ram, EVGA GT240
