UV mapping is one of my weak points... here is what I made to help me
PS I use mostly blender and some 3dmax
Am I wrong or the way to go with blender maps is by assigning seams and then by unwraping? Is there a more easy general way (ok I know this is now a blender forum but I am only interested in using Octane and not blender internal)
Here is a texture man I did to help me map things
- Synthercat
- Attachments
- GRID-COLORD.PNG (627 Bytes) Viewed 2335 times
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Hm, I fail to see the question here... and the exact point of the picture. Could you clarify a little more what is the problem.
Seams can help you to create a cleaner UV grid when unwrapping complex meshes. So, they are usually needed, yes.
cgmo.net
cgmo.net
- Synthercat
I just want to realise the workflow for blender->octane
would you say it's :
1) Model
2) Set seams
3) Unwrap
4) Export to Octane
1) Model
2) Set seams
3) Unwrap
4) Export to Octane
Ofcourse! (actually, theres no other way to do those steps
When you unwrap, you should also load a diffuse color texture, to see the preview of your UV grid in the viewport (draw type: textured, and the image must be loaded in the UV/Image Editor, for the current object).
cgmo.net
cgmo.net
Synthercat
go to blenderartists.org forums. there should be a few tutorials for UV unwrapping. It is quite easy in blender. Think of it as peeling a banana and trying to lay the peel flat on a table.
you could also try youtube for a tutorial.
win 7-64bit./Ubuntu 64bit 4gb ram. intel core quad q6600, geforce gt430 driver 260.89
- Synthercat
That's my point! That what I created this simple pic for...matej wrote:Ofcourse! (actually, theres no other way to do those steps)
