Memory full!
rappet
This has probably nothing to do with the OR plugin, but I am getting this error report on an AC17 file when trying to do anything. It worked fine and then out of the blue I got this error.
I was not running the OR plugin, but I had it running before.
I want to check if this is 100% not OR plugin related?
D:\Program Files\Graphisoft\ArchiCAD 17\ArchiCAD.exe
Unused in temporary folder : 25295.0 MB
Memory full!
Memory full!
OpenGL
NVIDIA Corporation GeForce GTX 580/PCIe/SSE2
Your OpenGL driver supports all necessary extensions.
Vertical Sync: OFF
Z buffer: 24 bits
Per Pixel Lighting: ON, 4.30 NVIDIA via Cg compiler
Stencil buffer: 8 bits
Memory full!
cheers, Jeroen
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
I doubt it's related to the plugin. You can quickly uninstall it via the Control Program so it would be interesting to see if the warning persists after that. Is it the same as http://translate.google.com.au/translat ... 6bih%3D668?
rappet
It is solved. It was an error caused by a curved mesh. No problems after deleting the mesh.
Ofcourse it was not the plugin :D , but I was under stress and had to find out... Thanx for responding Paul.
Greetz, Jeroen
