Octane not Picking up 60fps From Poser
morphious2013
Have a client that needs 60fps. from Poser, in the key editor, setting FR to 60fps, and upon export from Poser setting FR to 60fps. But rendering through Octane, still getting 30fps. Am I missing something? I know it renders only image sequence, which I can then import to Adobe AE, setting the import frame to 60fps will work. But not the image sequences from Octane. Any suggestions? Thanks.
Randall.
Hi Randall
The plugin will simply render 1 frame for each Poser frame. So you need to re-time the Poser animation to 60 fps. So if your Poser animation is 30 fps (say 600 frames for 5 secs), you'll need to double the number of Poser frames (so there is 1200 frames for the 5 secs). In Poser, there is an "Animation"->"Re-time Animation" option which may do what you need.
Return to “Poser”
