It is possible render animated object with path deform?
pov17
I tried to export an animation made using some cylinder that follow a path with "Path deform binding (WSM) modifier" with 3ds max2010x64 SP1
The result: artifacts
My machine:
2x Xeon 5520 2,27Ghz
8Gb Ram Samsung 1066Mhz
Gtx480
Windows 7 Ultimate
I think that an implementation for this kind of animation can be useful
http://img841.imageshack.us/i/testpathdeform.png/
kilaD
Probably some normal-issue. Is it a renderable spline or a cylinder?
Hello
pov17
kilaD wrote:Probably some normal-issue. Is it a renderable spline or a cylinder?
a cylinder the test is an animation of growing lines i've sent just a frame
Return to “Autodesk 3Ds Max”
