Problem export from max to obj
stanvisual
I am a new user, i try to export a file with lighting and material from max to obj. but i found that the file become one object when opened in standalone. There are no material in it ,is that correct?
FooZe
Hi Stan,
I think there may be some export setting not correct.
If you are using the inbuilt 3ds max .obj exporter, make sure "use material" and "create mat-library" are on (http://docs.autodesk.com/3DSMAX/15/ENU/ ... d30e521842)
Then make sure if you move the .obj, that you also move the .mtl file with the same name.
However, your best option is to use the unofficial 3ds max export script: http://render.otoy.com/forum/viewtopic.php?f=27&t=7572
Chris.
