Palm Trees Sundow Animation
ChrisVis
Hi there,
I started a little project just for fun and played around with some speedtree palm trees with a slight breeze of wind (turned out it was not enough to be really visible in the animation) and a sundown timelapse at the same time.
Simple setup of C4D terrain, a plane for the water material (LiveDB) and some sand and stone textures (only rough so far).
Next step is to animate the water, I would appreciate you experience on how to do real or fake ocean wave water inside of C4D with octane (or any other way?). I tried to animate the water material bump turbulence scale, but didn`t work out.
Imported the speedtrees into C4D and rendered the whole scene with pathtracing, 1000 maxsamples, little more than HD720p (1568x882), 1min per frame with 7 GPUs, took about 5 hours.
Had to use hot pixel removal, because of the water material, also didn`t manage to get a good sun reflection with all the turbulence going on from this perspective.
Here is the final animation, straight out of C4Doctane, no postpro, only some sounds added.
PalmTreesSundown1.zip
(6.15 MiB) Downloaded 222 times
Greetings,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
Return to “Works In Progress”
