video software not working with multi GPU
rappet
Adobe premiere elements 10 cannot work with multi GPU-drivers installed.
The thing is.. I had it working properly for a while, so I installed some older Nvidia drivers
But that did not help.
Searching the internet for the issue and trying different stuuf did not help me. Today I got support from Adobe and the result is that the software does work with just one GPU.
I have had it worked when all adapters were deleted and started with just one GPU.
When having all 4 GPU(drivers) installed, Adobe premiere elements 10 seems not able to handle and recognize the driver as being a compatible driver.
I tried a workaround to disable 3 of 4 adapter drivers, but that does not work,
I have to delete them, not just disable them.
Does anyone have any idea how to solve this or workaround?
greetzs,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
ChrisVis
Hi rappet,
which version of NVIDIA driver are you running at the moment?
Did you select only one GPU for Premiere in the nvidia system control panel (right click on desktop)?
It works only with version 320.18 for me, in older versions I could activate click markers on one or several GPUs but it never was saved correctly after hitting the ok button. Now it works and Premiere Pro or After Effects only uses one GPU.
But I didn`t have any problems starting Premiere Pro when all GPUs where active before, but had issues with After Effects. Maybe it is different with Premiere Elements?
Hope that helps somehow,
Greetings,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
rappet
Hi Chrisvis,
Thanx for your reply.
Yes, I did try several old and new Nvidia drivers and I also tried selecting just one driver for Premiers like you showed me, but now I am not sure if I tried selecting one driver at the same time with the 320.18 :?:
I will try that tomorrow asap and hopefully it works. If not... I Have decided to buy premiere elements 11, because that one works without a hazzle I am sure ( I have tried the trial verision).
I spend the whole weekend and today to fix it, so one last shot tomorrow :)
Thanx again and greetings,
rappet
ChrisVis
Hi rappet,
don`t forget to hit the apply button after hitting ok... otherwise the changes may not be saved.
Hope you get it fixed,
Ciao,
ChrisVis
rappet
Hi ChrisVis,
I tried, and too bad it did not work for me (I did apply).
Thanx for trying to help :mrgreen:
I have a 30day trial of AP elements 11 and that works.
If I don't find a solution in 29 days I will have to buy it.
greetz, rappet
Return to “Off Topic Forum”
