How reset Render Target to Factory default
morphious2013
I played around with the render target settings, and saved them as defualt. But, I would like to start from scratch. So, how do I reset the render target settings? Thanks.
Pls see the manual under "Load/Save as Default" - http://render.otoy.com/manuals/Poser/?page_id=52.
morphious2013
No such file exists. Ran a search also.
morphious2013
Sorry, let me specify. the defaultrendertarget.por. does not exist. Maybe called something else?
When you rightclick the settings tree in the plugin, is "Load from Default" an option, or is it dimmed? It will be dimmed if there is no default rendertarget, in which case each new scene will be from factory settings.
morphious2013
It is selectable. That loads the settings I saved as default.
Poser -> Scripts -> Python Shell -> type "poser.PrefsLocation()" will give you the folder where Poser preferences are stored, and that fold will contain the "defaultrendertarget.por" file you need to delete.
morphious2013
You tha Man!!!
Can you tell me what info I had wrong in the manual pls? I want to correct it.
morphious2013
The manual is correct, but for some reason windows search could not locate it.
Return to “Poser”
