Free Soft2Octane2013 [Obsolete]
Autodesk Softimage XSI (Developed by Face)
face
Here is a new version of the addon for Softimage to render animations in Octane.
[vimeo]http://www.vimeo.com/68366576[/vimeo]
The only change this addon have, is the ability to render animations on Octane v1.16 and 1.17.
Older versions of Octane doesn´t work with this addon.
This addon is for Softimage 2010sp1 and works also on Softimage 2013. Haven´t test it on 2014 but it should also work.
The addon includes all files for 32 and 64bit.
Have fun...
face
Edit:
The only issue i found is cosmetic nature. The version history in the about window isn´t up to date ;)
Soft2Octane2013.zip
(382.77 KiB) Downloaded 909 times
Edit2:
When someone have problems to install it, try to use this 64bit dll without some cuda stuff.
Octane2013_x64.zip
(176.46 KiB) Downloaded 806 times
http://vimeo.com/user2509578
PeterCGS
Uhm it says Octane_x64.dll cant be found, but the directory/name seems to be correct?
The old plugin had cudart64_30_14.dll, Soft2Octane.ini that the 2013 misses.
I tried moving over the Octane_x64.dll into the old plugin installation, and rename the plug-in to Soft2Octane_x64.dll and while it works to render with, the new -R function doesnt seem to kick in.
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
face
PeterCGS wrote:Uhm it says Octane_x64.dll cant be found, but the directory/name seems to be correct?
Hm, here it works also on a fresh installed Softimage 2014.
cudart_64_30_14.dll isn´t required because i runs without this.
And the Soft2Octane.ini is generated at runtime.
Have you uninstalled the old addon?
The new folder structure should look like this:
├───Application
│   ├───CommandMaps
│   └───Plugins
│           filebrowserPlugin.vbs
│           Octane_x64.dll
│           Octane_x86.dll
│           Soft2Octane.ini
├───Bitmaps
├───Data
│   └───Compounds
│           Set Octane Scatter.xsicompoundp
├───Docs
│       license.txt
│       Soft2Octane_install.txt
└───toolbars
        Octane.xsitb
face
face
Ah, it can´t work.
Have fixed coded the mesh node name to the one i use to test. Will fix it...
face
face
Have updated the plugin, now it should work...
face
PeterCGS
Thanx a bunch! :)
PeterCGS
I had to revert to the old plugin because I still cant seem to be able to install the plug (Treid on 2013 and 2013SP1)... Can anyone else try? Thanx!
face
I can disable the cuda info, maybe this is the problem...
face
face
Here is a test dll without the cuda staff for x64.
Overwrite the existing dll with this one...
face
Octane2013_x64.zip
(176.46 KiB) Downloaded 679 times
PeterCGS
Yes! That did the trick! :) Thanx Face!
Return to “Autodesk Softimage XSI”
