Hello,
I've encountered several crashes lately, on a scene that didn't crash at all before.
I've been testing this issue with 1.14, 1.16ab, 1.17
Each time, I want to batch render my animation OCtane does a crash and says "render is complete" Apparently, my polysmooth is crashing octane, but I don't know why...
THe maya crashlog is attached (2114)
Next crash is hapening when I try to open a scene with several shaders and texture image files. Whenever I open the hypershade, on the refresh of the thumbnails, it crashes.
Maya crash log attached (2111).
It is happening with all the mentioned plugins.
Does anyone have an idea why?
Fred
Wierd Maya crashes
- Attachments
- Maya_crash_logs.zip
- (4.21 KiB) Downloaded 223 times
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
Thanks for report.ciboulot wrote:Hello,
Fred
The second log (2111) is nothing to do with Octane - as there is no Octane modules in callstack of this crash, only OpenMayaRender.
About the first one (2114) - there should be the second file of this report, the .dmp file with the same name, only this file can show what exactly causes the crash. Or you can give me the scene (if it is not under NDA) to I be able to reproduce this on my machine (it may be even better to catch the reason)...
Hi Jimstar,
Thank you for your answer.
Here are the dmp and the maya scene. Hope it helps.
Fred
Fred
- Attachments
- MAYA_Crash_Scene_DMP_LOG.zip
- (3.1 MiB) Downloaded 260 times
