Feature request
Moderator: BK
SimonJM
Hopefully simple ... with animations it is possible to select jpeg as file output type, along with a compression ratio. Any chance of offering that as an option for a 'normal', static render file save type?
t_3
SimonJM wrote:Hopefully simple ... with animations it is possible to select jpeg as file output type, along with a compression ratio. Any chance of offering that as an option for a 'normal', static render file save type?
since i recently added 4 options to the save menu (called "autosave *" btw ;)), i don't mind adding another two. the most complicated part is to find a place for the quality slider - the tabs already get really crowded. or just use 100% always? who would save stills to something less than best quality :lol:
[edit1]: found some place (for the slider);
[edit2]: done ;)
ps: i already thought about that when implementing the autosave, but was just to tired then, so thanks for making me finally include it...
SimonJM
Thanks and a pleasure - anything else you want to be made to do? ;)
Return to “DAZ Studio”
