Hello
I'm processing a sequence with a 4 titan's GPU.
When I process in octane, the render is so fast that I have a weird noisy pictures.
The only way to avoid that will be to raise the sample rate to allow c4d to record the pictures correctly?
Here is my scene
https://dl.dropboxusercontent.com/u/200 ... est_ID.mp4
Is there a bug?
Here is a second example with a material ID
https://dl.dropboxusercontent.com/u/200 ... icture.mp4
thank you
Noisy pictures
this is weird, it seems like some frames are saved before the render is finished
please could you post your nvidia control panel settings and the gpu octane settings in the plugin?
have you installed also the standalone? have you tried with exporter + standalone?
Yes the two of them are licensed.have you installed also the standalone?
not yet I'm running right now, but with 128 sample rate for an Object ID (no more a necessary)have you tried with exporter + standalone?
I think the console running is too fast. I have several crash.
Here is what you want
and
this is super weird, no problem here in rendering your scene with my poor dual gtx 460
the only thing that comes to my mind is to try to disable the 680 and stay only with the titans or the opposit, only the 680 and disable all the titan
the mac driver for titan is new, maybe is necessary to wait an update?
are you with a netstore and a macpro?
what is you plugin version? did you try with 0.59?
