Problems with live refresh times since version 1.14
charge
I have been having issues with the live refresh times in the maya plugin since version 1.14. Basically, when I render from within Maya I get an initial update with maybe 2/10000 samples and then I do not get another update until all of the desired samples has been rendered (10000/10000).
To make sure the issue is not something inherent to old scenes I made a new scene that only contains a cube and a plane but I get the same issue.
The "rendering..." dialogue that pops up starts with a value of 100% and does not update during the render.
IPR works fine.
If I install 1.13 I do not have this issue.
I am using Maya 2013, and my computer spec is in my sig.
Thanks for any help.
Intel Core 2 Quad Q6600 (Kentsfield) @ 2.4ghz. Asus P5N-E SLI (nForce 650i). 8GB ram. 6GB Geforce Titan + 2GB GeForce GTX 560 Ti. Win 7 x64.
charge
I have upgraded to 1.17 and I still have the same issue.
Is there any way I can activate a debug log file or equivalent to help look into this?
No, there are no logs which can help to catch the reason.
I will investigate it, thanks for report...
charge
This issue seems fixed with 1.18
Thanks.
Return to “Autodesk Maya”
