Displacment map support?
bpzen
I think ?I know he answer but wanted to make sure, can octane use/understand the displacement map in a poser texture set up at this point?
Is there a way to get a similar result if not?
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Not supported, but I think Otoy have said it is planned.
Instead, either increase the bump power (on 1.16 onwards), or you can convert your bump map to a normal map using a free photoshop of GIMP plugin and that will give a similar result (plug it into the "normal" pin.
bpzen
thanks paul
Return to “Poser”
