Texture limits
bpzen
I am getting a message from the plugin, using 1.16
"Total number of textures exceeds the limits for Octane Plugin set up"
This render has no issues or errors running 1.13, I changed the defualt.py file to accommodate the 4 gig card i have and selected that card , high priority, apply
Is there another place I should be looking to set this up the material count is
Total Num Texture Maps (rgb) : 37
Total Num Bump/Trans Maps (grayscale) : 33
Total Memory Required for Textures : 1031.0MB (assumes only LDR textures)
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
KleanZlate
Click 'Setup' under the Settings tab. There you can select 600 series under 'Video Card'
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
I will change the warning message to make it more clear that you can set your card limits in the Setup screen to:
'The total number of textures exceeds the limit set in plugin Setup. Click the Setup button on the Settings tab if you need to specify different texture limits.'
Return to “Poser”
